Dos inversores con baterias diferentes
Hola
Tengo una instalación aislada.
Puedo hacer una instalación en paralelo de 2 Victron con baterías de litio diferentes.
Tengo un VICTRON MULTIPLUS II CON UN JUEGO DE BATERIAS 10 LITIO, + SmartSolar MPPT 150/35 & 150/45
Puedo instalar otro VICTRON MULTIPLUS II CON UN JUEGO DE BATERIAS 3 LITIO diferentes , + SmartSolar MPPT 150/35 & 150/45
It’s generally not recommended to use different batteries on a parallel installation.
Both inverters MUST share a common negative. With different batteries of different capacities, the first inverter to hit ‘low battery’ will shut down the entire system.
If the batteries share a common voltage profile, then there is no reason not to parallel the DC.
Both inverters must also be the same model & firmware, meaning that you cannot (currently) parallel a 48V and a 24V system.
OK GRACIAS
