Does Orion-TR connect to power in or distributor
I have a 48v system in my 40’ motorhome with the Lynx Power In/Shunt/Distributor setup in series and hooking up the Orion-TR Smart 12/48-8 DC2DC. Just verifying that the OTS hooks to the Distributor side of the Shunt, is that correct? I’ve heard only batteries should be on Power In side, all else on Distributor side.
Thanks!
Doc
You are correct, Orion to the Distributor so that power has to flow through the shunt to be measured.
Thanks! Just making sure that my reasoning was correct. :+1:t2:
