installing on a travel trailer with a 200 AH LiPO4 battery, to charge the battery with the F250 diesel alternator while driving.
When hookup up to shore power, the battery charging line also provides 13.7 V to charge the battery.
When installing the converter in the travel trailer, can I connect the shore power charging wire to the input terminal as well as the alternator power supply wire? or should i buy a switch to isolate one from the other? or the shore power charging line should not be connected at all?
I realize that 99% of the time, the truck or the shore power will be used, but not both. the 1% of the time they both may be live when docking or undocking from the campground, and the truck is still running and connected.
Thanks for the technical help.
Sportsguy
