I want to dim an LED indicator bus light bus (8 lights) on the negative side with a Pwm dimmer. In other words, each switch activates its own light, but I want to dim those lights. Better way than negative side PWM dimming? How would I wire the bus after the switches, so I can dim all of them for a night marine application. Does a PWM work with negative side only? I realize the PWM has to be powered, but what happens to output positive + in this scenario?
Related topics
| Topic | Replies | Views | Activity | |
| Dimmer Led Lampe? | 9 | 167 | 19 June 2026 | |
| Illuminated switch for Orion tr 12-24 dc dc converter | 0 | 72 | 2 January 2025 | |
| 12V Dimmer zur Verwendung im Wohnmobil bei Steuerung über Venus OS | 9 | 162 | 17 April 2026 | |
| BlueSolar PWM DUO LCD&USB 12/24V 20A | 5 | 113 | 24 January 2025 | |
| Feature Request SmartSolar: add a step-down converter to the output side | 0 | 26 | 20 October 2025 |
