Feature Request SmartSolar: add a step-down converter to the output side
Suggestion: add a step-down converter to the output side
Not all loads operate at the default output voltage — for example, some LEDs work at a much lower voltage. In addition, certain LEDs may perform perfectly well at a slightly reduced voltage, which can have a favorable effect on power consumption.
Therefore the suggestion: add a step-down converter to the output side.
