DESS: Price chart (Tibber) in dashboard (suddenly ?) wrong
I recently noticed that the price graph in the dashboard (attached) differs to that from Tibber (attached)
Both attached pictures where taken at the same time and while the Tibber pricing shows a very high peak this evening the dashboard shows a higher price this morning.
It might be that the absolute values do not match due to my equation in the dess config is not accurate, but as it is a simple (p+something)*1.19 the shape should at least match, which it doesn’t.
With the current observed behavior (which I believe was correct some time earlier when using the node-red variant - I did update the system recently and switch to the native support afterwards) I am now buying at wrong times …
Any idea what could cause this behavior ?
PS: I already did a switch off/on in the VRM menu, hoping to retrigger some pricing recall/update, but no effect …
Best regards
Ulrich
Hi.
Same probleme here.
I think Tibber has done some changes with the API. In IOBRoker there was an adapter update few days ago. Now you have to choose and set a checkbox, if you want to see prices.
Maybe Victron has not adapted these changes yet.
Today, i checked the normal DESS in VRM Portal.
The Prices seems to be correct.
In NodeRed the day ahead prices are from tomorrow.
I also just noticed wrong price of tibber for tomorrow - almost 30ct of.
Is this related to switch to 15min data interval maybe?
Update: Switch to 15min intervall (new DESS setting) - now it seems to be correct (swtich takes ~1h until the display changes).
I am also wondering how Victron gets my personal price which should include local (net provider specific) infra costs (Netzentgelte). For this I assume I would need to provide an API token to DESS - but I dont see this in the settings.
