Tibber prices not displayed anymore on VRM
Anybody else having this issue with Tibber integration? DESS seems to work, i.e. there is a schedule and it also makes sense (charge at night when prices are low).
But in VRM the price chart for today is empty. It just started yesterday, i.e. prices for today where not displayed (they are usually updated around 13:00) and they are still not displayed today.
Same here.
the same here!
I’m in the same boat. Switch to another data provider had not solved either.
The GX seems to be confused too. Last night it hang up and the MP2 ran out of control too. I had to completely restart the machinery. It now bothers about low battery at 15% SoC as it missed out loading last night.
German Tibber user and same = same here… After almost 24hrs an official comment and (if possible) a way forward would be much appreciated @dfaber
Best regards, Jochen
As to comments from past threads, I have tried updating the DESS data set with no results to having the forward prices displayed again. No quick help available though.
Looking into this. It is probably not too hard to find (and fix).
Works again, thanks!
Are the prices correct?
In my prices dashboard the prices for today rest of day are wrong.
So DESS wants to charge in the late evening in the wrong hours.
@dfaber Could you pls check?
Right would be:
21:00 24,2ct
22:00 24,2ct
23:00 20,8ct
0:00 23,3ct
same problem here, the prices for todays end are not correct …
Helaas nog geen prijzen voor morgen zichtbaar, wat wel vreemd is dat de planning wel aardig klopt.
Unfortunately, no prices for tomorrow are visible yet, which is strange because the planning is quite correct.
Thanks for letting me know. Working on a fix to get the correct prices in.
It should all be ok now. Thanks everyone.
Yes thanks! :slight_smile:
For Awattar (Austria) I still get no prices in VRM.
@peregrines Thanks for reporting. That too should be fixed now. The system had some troubles when prices didn’t change from one hour to the other.
Perfect! Indeed works now :slight_smile: Thank You for this information!
