I have a Victron Inverter model Multiplus-II 5kVA 48/5000/70-50 and firmware version 2623494 and recently had to replace my Pylontech batteries as the original batteries had become swollen. The batteries are US3000D. However since the replacement batteries were installed, I have noticed that the maximum state of charge (SOC) has steadily been dropping and now only reaches a maximum SOC of 91%. Any idea why the batteries are no longer charging beyond 91% and advise what can be done to correct this issue? (I am the homeowner and not an installer or technician)
First thing would be to check min/max cellvoltages, when it does not charge anymore.
If you replaced some modules, but not all, then the modules may just be heavily out of sync. Some at 100%, some at 80% will make the BMS report 90% overall, without charging further, cause at least one Module blocks.
In that case you would see a different second part on the cell voltage ids, for example 0102 for the max and 0107 for the min. (Second part is the module id). Voltage difference should be not above 50mv at the maximum charged state for normal operation.
Then, it would depend on how big that difference is. If too big, it may be easier to charge each module separately to 100%, then reconnect them again.
Sometimes however, that is not an easy option due to physical connection layout. Then - if the natural equalization doesn’t seem to cut it - you could use a node red script to help the stack getting back on track. (had to do the same after extending my stack, see Assisted Top-Balancing with Node-RED for an example flow )
Hello @Sharrynvt,
Have the new batteries ever been balanced for an extended period using the function " Keep batteries charged"?
As @dognose described, you can see the minimum and maximum values for the batteries under the battery section on the GX device. Alternatively, check the LEDs on the batteries. If they are all lit green and no longer flashing, then they really are full.
What firmware is your GX device running?
