I wonder about the maximum length of the external current sensor of the Multiplus 2 GX. I see it exists with a 10 meters cable length. Is it possible to add additional length ? What is the reasonable limit ? 20 meters ? more ?
Thank you in advance for advises
Jean-Luc
Maximum is 20m after that signal degradation is an issue. (And before if is is not done right)
Use cat 6 good connections and keep it away from things that cause interference such as ac cables and other devices that can induce noise.
My setup requires slightly more than 25 meters, so after initial testing with the stock 1m cable I soldered up a shielded 2 x 0,4 sqmm cable and my readings were same or similar. I am running it for a few months now without issues
Thank You. That works
