"Control Panel" button not available in VRM
Hello VRM team,
I encountered an issue with the “Control Panel” button—it is not available on the VRM installation “Dashboard” page after enabling the functionality in the settings.
The “Control Panel” was configured according to the VRM Portal manual: 5. Control your devices in VRM
I can open the “Control Panel” only via a direct link from Settings → General → Inverter/Charger Control.
Venus OS VRM settings:
System components:
  1. Cerbo GX MK2. Venus OS v3.80~14.
  2. Multi RS Smart 48V/6000VA/100A. Firmware 1.29. No solar.
  3. DIY 280Ah battery with JK BMS
VRM Site ID: 935779
P.S. I have installed and configured 7 ESS systems and have never encountered issues with the “Inverter/Charger Control” configuration before.
Best regards,
Vladyslav
I have exactly this issue.
It was already there on Venus OS v3.70-72 (site-id: 888284). Other systems in my account don’t have the issue, despite the same SW level.
I have raised this with the team. Thanks for the report.
Thanks Nick.
EDIT: Just did a full Venus OS reinstall which actually seemed to have helped. the button returned!
Issue found. Fix should be live in the next 30 minutes or so.
Many thanks for the quick fix! :partying_face:
