KamFlyer
(Rob Dover)
October 15, 2026, 3:41am
1
Recently my VRM has lost the ability to control the inverter input current limit.
First noticed about 10 days ago then returned to normal and now has disappeared again.
It does still work normally via the local display however.
I have turned Inverter Control off and back on via the VRM control panel with no success.
Is this just me or more widespread?
I should add I haven’t changed anything recently or updated any firmware. Working one day, gone the next!
TIA
Just looked at mine, but yes its not there anymore
Must have been changed in a recent vrm update
@Barbara did this change or is it missing?
AlexV
(Alex)
October 15, 2026, 12:26pm
3
Hi all,
I have also noticed this problem. Can not control anything from vrm. Changing the mode only highlights the mode selected but does nothing. (All modes get highlighted eventually)
One thing that i did notice is that if I simply open Console from VRM and return to the dashboard all works again. Note the header says Inverter #2xx after opening console and close again it shows the name given.
Possibly this is linked with the following issue also.
My Quattro controls and state are not showing correctly in VRM. They are displayed correctly on the local control panel. I have tried disconnecting the device and rebooting the OS so it was no longer detected and deleting the device from VRM. Then reconnecting and rebooting however this didn’t resolve the issue. As can be seen in the screenshots (Wobbly & Control Panel) on the local panel everything is correct yet VRM shows the status as Off yet clearly in the background you can that it is inve…
Hope VRM team can find a solution.
KamFlyer
(Rob Dover)
October 15, 2026, 1:42pm
4
Glad to know it isn’t just my installation.
And @AlexV you are correct, if I open remote console through VRM and immediately close it, the inverter controls are working again.
It does! So looks like a bug! @Barbara
DS4AUK
(DS4A)
October 15, 2026, 8:47pm
6
Looks like a VRM issue. I have the same loss of functionality on every installation in my fleet.
There was also this issue from July: Setting amps is missing in VRM
nickdb
(Nick)
October 16, 2026, 6:07am
7
This issue is with the VRM team, should be sorted soon. Thanks again for the reports.
Wobbly
October 18, 2026, 9:28am
9
That’s good to know. I’ll wait for it to start working again. Thanks.
Barbara
(Barbara Jansink (Victron Energy))
October 19, 2026, 7:10am
10
Hi all,
The fix for this has been on BETA this weekend and we will put it live today.
Thank you for making us aware of this!
Wobbly
October 19, 2026, 11:20am
11
Thank you, I was looking earlier and noticed it is now working again.
KamFlyer
(Rob Dover)
October 19, 2026, 12:16pm
12
Yes! Thank you team. Looks like it is back to normal.
