Contactor cycling rapidly when car fully charged
I noticed yesterday that the the car had stopped charging (reached its preset limit) while the EV charger was set to 6A but the charger contactor was cycling on and off (making loud noises.) No current flowed during this time but it’s clearly undesirable for the contactor to be cycling like that.
Any ideas on what could be causing this or how to stop it?
I noticed the same behaviour, at least since Firmware 2.03: when charging is stopped by the car, the contactor/Schütz in the EVCS switches on-off, waits 1-2 seconds, does it again, until I manually push the “Stop” button in the web ui. It’s especially annoying during nights, since it’s quite loud.
Happens on all firmwares since 2.03 up to current 2.09.
EDIT: there’s this [1], i’ll give it a try.
[1] Victron EV Charger clicking (start/stop) constantly
I would try setting “Contactor active when charged” to enabled in the Charger settings. That should keep the contactor engaged when the vehicle is fully charged.
