I have an Epever Tracer solar regulator and recenty I installed a Cerbo gx victron and a MultiPlus-II 12/3000/120.
I’d like to connect epever into cerbo via rs485 using epever converter cable “CC USB RS485-150U”.
If I put usb connector into cerbo, I don’t see solar data in the home page of cerbo.
No option exists in the Cerbo menus to enable the input of information and represent it on the home page.
Regularly data from epever using same cable reach a pc with solar guardian software then all the data are exiting from the rs485–>usb.
Does someone has experience on connecting epever with victron cerbo?
Epever isn’t supported by Victron so it won’t work.
It’s a simple as that.
Without writing custom code, e.g., via NodeRed and modbus + virtual device, - you won’t see ePever in Venus
Hi,read this my post on old forum,user Kassl make script on Github.
https://communityarchive.victronenergy.com/questions/69610/epever-mppts-on-raspberry-pivenus-os-usb-port.html
