Dual voltage system (24v 12v) on the same solar panel array
Hi all. I have a solar array with a victron mppt 100/50 solar charger connected to a 24 v lithium battery.
I also have a agm lead acid battery (12v system) than i want to charge.
Is there a way to properly charge both systems via the same solar panel array?
can i connect a second victron mppt solar charger to the same array?
Or connect a victron dc/dc 24/12 converter charger to the output of the existing solar charger?
Thank you.
John.
hi
You already have the answer in your question:
You have to use an “orion DC DC smart charger” in your case.
It is not possible for an mppt to charge 2 different types of batteries.
