SmartSolar MPPT and a Skylla IP65 charger in parallel
I am planning to use a SmartSolar MPPT 150/70 Tr VE.CAN as the primary charger for my battery bank (4 × Pylontech RT12100G31 = 400 Ah total).
To increase the total charging current, I am considering adding a Skylla IP65 12/70 (1+1).
Can these two chargers be used in parallel to charge the same battery bank?
If it is possible, should I connect them via VE.CAN for synchronization, or should they operate independently?
Thank you!!
Yes they can be used in parallel, provided the voltage settings are correct. However, you will need a GX device to interpret the CVL from the Pylontech and communicate that to the MPPT and iSkylla units.
