Hi.
I have a 3 phase setup with multiplus 2 48/5000 and two mppt rs 450/200 and a pylontech force L1 battery with 518ah.
As soon as i power up it triggers the high current alarm on the battery thats at 100A no mather what other parameters i set.
I have the ESS assistant loaded and enabled feed back to the grid and i have set the maximum charge current in DVCC at 100A.
Is there a solution for the mutiplus to recognice this and simply charge the battery with tha maximum of 100A, power the loads and then feed back the ecxess?
The only solution i found is to reduce the charge current to 50A each on the mppt but then i loose a lot of solar.
Grateful for any help or tip.
