Dear Forum First best wishes to all of you. My point for now: I have a small ESS system set up around a Multiplus compact 24V 1200/25. Once used in its original setting, (just inverter) it loaded the battery up with capacity.up to 600 Watt as per spec. I apply it now in ESS mode, external control configured in NodeRed. When charging the battery its loading-capacity is limited to 320 watt eventhough a setpoint higher is commanded via the “AC Power L1 Setpoint” label. The grid current limiter is set to 16 Amps so that should not be the issue. Anybody any idea? Thanks in advance.
Related topics
| Topic | Replies | Views | Activity | |
| ESS limit (dis)charge power in watts | 9 | 192 | 5 February 2026 | |
| ESS: Muiltiplus only charging on excess power, but not from grid (e.g. keep battery charged) | 1 | 127 | 6 January 2025 | |
| MultiPlus-II Inconsistent Battery Charging | 0 | 100 | 15 January 2026 | |
| Multiplus current limit not working in ESS mode | 19 | 493 | 8 January 2025 | |
| ESS battery charge rate from grid | 6 | 558 | 10 November 2024 |
