Changing battery selection to "LITHIUM" in Multiplus II inverter/charger
Can I change the battery type to lithium in my Multiplus II via the Cerbo GX or through the VRM portal? It is connected to the Cerbo G via VE.Bus. System is up and running, I just need to change the battery selection to Lithium. Tried a search, but came up empty. Thanks
Just another noob
In VRM, go to the device list and download the remote VE configuration file and modify it using Veconfig 3. You will need a Windows PC. Go here and download the Veconfigure tools.
