Cerbo MK2 Can Busses
Could you please reconfirm that the two CAN bus ports of Cerbo MK2, called VE.Can 1 and VE.Can 2, are good for BMS connection like before the BMS-Can of the normal Cerbo?
We want to make sure we don’t have problems connection Pylontech batteries to new Cerbo MK2 instead of normal Cerbo.
Hey Jochen. It worked perfect under firmware 3.42. Currently there is a problem with Cerbo MK2 v3.5x with Pylontech batteries. Victron is working on it.
The issue that @Frederic refers to is now considered solved; see here for more info;
