I am new to this forum and need your help. A Cerbo GX was installed on which special firmware (Venus OS) runs. The Cerbo GX has not started since mid-August, and I was able to narrow down the error via the serial interface. Unfortunately, this firmware cannot be replaced, and I have to try to get the Cerbo GX working again somehow. The internal file system check software reports that there seems to be an error in the file system. Attached are two screenshots showing the errors. I suspect that this error is somehow related to Victron’s database problem in August, or it’s just a stupid coincidence.
Thank you very much.
Best regards,
