I really hope someone can help me with this. The website is so convoluted that I had 12 pages open but not one of them told me what I needed to know. Each one just lead to another page with yet more links but none of them clear on the subject. (Please, people, streamline this mess and tighten it up!)
So my first question is, can I just get a telephone call so someone can walk me through correcting my Cerbo GX issue???
Now, I have v.3.63 running on my Cerbo GX. It appears to be connected, but not one post mentions the distinction about where, exactly, to confirm this. Are we looking on the bluetooth app, on the online portal, on the touch display or what… and what menu… how do i get to it??? Clearly, I need support with this product because there’s not much in the way of “step-by-step” instructions.
What I have is the two lights blinking on the Cerbo (top LED white, bottom one is blue). When I open the Victron App on my Android phone, I get the indication of full signal strength for both the Cerbo GX and my Smart Solar MPPT Charger 150/100 VE.Can - I assume that’s bluetooth signal strength and not the Wi-Fi signal. (And BTW, no problems with the MPPT at this point.)
Now, clicking on the Cerbo GX in this device list (at first) caused the blue LED to go from blinking to constantly ON, and the top LED continued to blink white. I say “at first” because on a 2nd attempt, the result was different. On this 2nd attempt, the bottom blue light went OFF altogether, and the top light was blinking GREEN, not white! So it did not even behave the same way after repeating the same exact steps! That’s just for starters… and I have very little confidence so far.
Now, the unit did connect successfully to the VRM when I first connected the Cerbo GX to my system and I “turned it on”. Then it just stopped working - neither the Classic nor the “new UI” work anymore, but I did have success for about 10 minutes, if that.
After many attempts at reviewing settings, and trying updates, nothing has worked. (One thing important - I cannot remember if I attempted an update EARLIER ON in the process, so I must admit that possibly, I had v.3.62 or 3.61 working properly, and then “intentionally” updated to 3.63 which I thought could only help, but maybe that actually introduced the problem.)
Seeing that there are clearly a slew of connectivity issues for this device on the support community chat, my next question is, did I actually CAUSE the problem, and should I roll back my firmware to an earlier (or previous) version? If so, then how do I do that? Can it be done from the VictronConnect mobile app, or only using a flashdrive? And if the latter, then what accessories do I need to buy now to perform this task and how many weeks am I going to wait before I receive them?
There are more problems, still. But let’s just start with this for now.
Honestly, my MPPT did NOT work from the very first moment I installed it, and I already replaced that with a new one at significant additional cost (FYI: the warranty on the 1st one is still up in the air and the dealer was “unable” to reproduce the problem so I don’t know where that leaves me). Yes, the 2nd MPPT charger worked immediately without any problems whatsoever and that is a good thing… However, after experiencing numerous additional problems - now with the Cerbo, it begs me to wonder how Victron can run a business like this!
What are my next steps to get the Cerbo connected to my Wi-Fi again? I’ll repeat that it “appears” to be connected, and my wi-fi network is even listed in the device settings (on the mobile app), yet the VRM still won’t open the UI.
Can you also explain what a blinking white light on the top LED means, as that’s not displayed on the unit (it only says green or orange).
Thank you. (I’d much rather a phone call or an email, if you have my address there.)
