Cerbo GX Mk2 Port Plugs
Soon to be locating / installing in beach environment. High humidity, Salt air, high temperature. Temperature is resolved, basically an enclosure with temperature controlled fan(s).
Looking to cover / fill unused ports. “Through” covers better, then won’t need dielectric gel to seal. RJ45 / USB are easy enough using off the shelf. Others? Not so much.
