Cerbo GX Expansion Modules?
Good morning everyone,
Is there some sort of solution to have an expansion module for I/O’s on the Cerbo GX ? Is this a product in the works ?
The two relays, and four analog inputs are great, but I feel they are prohibitively limiting. It would be nice to able to have an additional expansion board with 4 more relays and 4more analog ins or outs.
Maybe there is an unofficial solution ? I dont want to install a full fledged PLC at my offgrid location.
There is an IO expander launching soon. Search for that here and you will find some info.
Excellent ! Could not find anything on the website. Ill search the forums in that case. Appreciate it Nick.
It is called the GX 150.
It would be interesting if Victron offered different variations of this unit. For example, an 8 relay module, a 4 analog in 4 analog out module, a mix and match module like the current iteration.
Anyways, appreciate you listing the number.
We have a Waveshare 8-Ch Ethernet Relay Module (B), using Modbus TCP from node red. Used for DC/DC control and load-shed features in our motorhome. Shelly relays are another option, using MQTT from node red over WiFi. Not as elegant as a Victron solution, but they work.
