Hi, we have a Cerbo GX going. Every 2 weeks it crashes and I have to restart it. Note that sometimes when viewing VRM there is a yellow box with the message saying that it cannot update the stats because it’s overloaded. However, using the web portal I can get the stats. What’s going on?
Thanks!
Hello Inferno,
What version of Venus OS are you currently running on your Cerbo GX? The latest is Version 3.62. Have you made any changes to your system recently?
Do you have GUI mods, scripts or Node-RED flow that could trigger this? Might be due to lack (running out) of disk space..
Hi @Tardis & @ChiefSolar
Thank you. The version is v3.55 Once upon a time we ran the MicroInverter reporting, a script that showed usage in the VRM portal.
We don’t currently run it, and I’m monitoring space usage. Is there any way to look at previous crash logs maybe to hone in on the problem?
