Cerbo GX fusing from Lynx NG BMS
Since the Lynx NG BMS has a 1.1A resettable fuse on the Aux + pin 1 output, is there really a need for another fuse for the Cerbo GX (supplied with 3.15A) or ATC/ATD feeds (recommended at .5-1.0A).
It seems redundant to have so many fuses in such a short run, and would be cleaner with fewer failure points to simply use the BMS’s internal 1.1A fuse.
No, a second fuse is not needed.
