Lynx distributor glitch
Hi all,
I am running Victron LFP with a Lynx BMS and a Lynx distributor. All systems have the latest firmware.
Day before yesterday, the Cerbo GX reported an alarm coming from the lynx. The alarm stated that the fuse #1 has blown. This fuse is the house fuse with 200A. However, three seconds later the fuse was ok again and duringnthe whole time no power loss to the house was seen.
Has anybody an idea what could have caused that?
The system is currently charged by one Victron MPPT and solar, having it’s own fuse at the distributor
And it hapoened again. For about three seconds the fuse was declared blown…
Poor connections?
possible but not likely.
All connectors are greased with copper grease and tightened with a torque wrench.
It now happens more often…
Always three seconds and no other measurement indicate any problem
Small correction. In counting the fuses I was off by one. Victron starts with Fuse 1 and I thought it starts with 0.
Having said that, the first fuse is installed but nothing connected to that circuit (at the present time)
I’ve noticed that I did not post the result.
Itnwas indeed a loose connection. I only hand tightened the fuse holder because I thought I will install a cable ontomit soon…
