Hi to all.
I have been having this issue since February 2024 and it continues to occur. My Cerbo GX is currently running Venus 3.52. First question, should I update to v3.54? Beginning last year in late January or early February, the Cerbo began to reboot at random times. In July, I decided to do a clean install of the Venus OS. This clean install improved the reboot issue from every 15 minutes or so to sometimes running for 6 or more hours. During the heat of this past summer, I moved the Cerbo out of my RV basement into the air conditioned part of my coach. At that time I verified, using a recording Fluke volt meter that the voltage supply to the Cerbo was a solid 25-27 volts.
I am running Venus OS Large and using Node Red to provide load shedding routines to prevent overloading the inverters. Using the top command, I can see that my CPU load varies between 25%-72%. I do not know what other information that the top command would be helpful.
I know that the Venus OS software can be run on other devices, but I am not sure how this would help. I have two Multiplus II 2x120 units connected in parallel. I also have a smart shunt, a BMV 712, and a 150/100 MPPT solar controller all reporting through the Cerbo.
Based on the strong recommendation of a software specialist, I added a 32Gb memory chip to the Cerbo, but as far as I can tell, the Venus software will not use that extra memory for operating software routines.
The second recommendation was to run the Venus Large on a separate dedicated computer, but I do not see how that would interface with the Cerbo.
I was told that the latest models of the Cerbo GX has a more powerful CPU, but I have not seen any solid mention of this.
I just got a message when trying to login on my network – “Application exit (RuntimeError: Aborted(both async and sync fetching of the wasm failed). Build with -sASSERTIONS for more info.)” I am not sure what this means and if I should do something else.
I just did a “Power on Reset” by removing power for about 30 seconds and then restoring power. This seems to reduce the number of re-boots for a period of time.
I notice the re-boots most often when I am running the generator. When I am running the generator, the Start signal is the Cerbo GX Relay #1 picking. When the Cerbo re-boots, it drops Relay #1 signaling the generator to turn off. After the re-boot, the Cerbo picks the relay back up and the generator re-starts. During a recent generator run of 4.5 hours, the Cerbo re-booted 4 times that I know of.
I have another post that is active regarding the Warm Up and Cool Down time periods when I run the generator. Basically, these features do not work. I wonder if these are separate issues or stem from the same, unidentified problem.
Any thoughts or suggestions are appreciated. I am well and truly stumped.
