Brief SmartBMV-712 Aux Voltage Not Displayed, no info
If I configure the AUX input to show up in Brief, as it is allowed to be shown, it really doesn’t display anything useful. A configurable voltage range would help, or even just show the voltage. I understand it can’t show a level, as it isn’t part of the shunt function, but I’m not really sure why we can configure this at all if it doesn’t show anything useful. Again, allowing for a voltage range would be good enough for this to display a ‘level’ of rough house battery charge. (I’m using a 24v lithium system in combination with some basic 12v starter battery items)
Question 1: Is there any documentation for the icons that show up on Brief circles? I get 3 different battery icons currently.
Question 2: There is some disambiguation between “Not configured” and “None”. Once you touch the setting, you can only put it to None, is this the same as “Not configured”? It appears to be. Maybe allow us to put it back to “Not configured” rather than “None”. I certainly get a circle and not a no-circle once everything is None.
Question 3: Is the default circle and monitor in Brief the main auto-selected battery monitor for the system?
Hey @natewin thanks! looking into this.
