When installing a lithium battery kit and BMS on boats, we use a 300A smartshunt to monitor engine/generator batteries, such that they can be displayed, as there is no other simple way to do it.
The Lynx BMS monitors and displays the house battery voltage and current, and the installed 300a smartshunt has 1 or 2 engines connected to it. We do not feed current through it, just connect a 2.5mm2 cable to one of the negative posts.
There is one issue in doing this though. When viewing the battery, it shows the current and can drill down to the SoC. We’re not interested in any of this data on a start battery, and it can make it confusing for owners, especially as it is all zeros, and they wonder why it says “Idle” and the second connected battery says nothing.
I think this is a nice way to do this, but would like to be able to turn off all of this ancillary information. Something like a checkbox to show Current, SoC, etc. or maybe a configuration setting in the VC app, where it is set as a voltage meter only, similar to how it can be set as a DC Energy Meter. Setting it as an energy meter does not work.
The other downside is that the Auxillary measurement does not show in the device list, just the main measurement and you have to drill down into the main measurement to see this.
An enhancement for the future please.
If you are happy to add Node Red programming then V3.60 which is in beta has a facility called virtual battery. I have a Smartshunt set as DC Energy Meter measuring the DC System on my boat and the aux connection goes to the starter battery. In Node Red I have created a virtual battery called Starter Battery and set the DC Energy Meter aux voltage to this. If you want, I can add more details.
However, whilst this gets a box on VRM dashboard, I still have to drill down into devices locally and ignore all the other info. I like your suggestion for have a voltmeter function for the SmartShunt.
I don’t believe this should require Node Red. I think it is a simple solution for Victron to add the functionality of Voltage Meter into a shunt. Plus, it is a far more elegant solution.
[moderator edit: removed inappropriate staff tags per the Community Guidelines]
Why are you using a shunt for voltage only? Use a Bluetooth voltage monitor like BM2 or smart battery sense.
The Smart Battery Sense does not send info to a GX device.
Interesting, that’s unfortunate it can’t receive bluetooth data from the battery sense. I guess the customer would be even more confused having to view a separate readout/app.
Actually the smart battery sense can send battery voltage data to the GX device. You just have to know how to get it there.
We use the shunt, as that can measure 2 batteries for only a couple of bucks more than the smart battery sense.
Or, if there are DC/DC chargers fitted, we connect them to the GX device and monitor start battery voltage. Without using VE Direct, and saves running cables.
