Battery monitor alarm 512 - Module 2
Hi!
I am running a Multiplus 2 3000 with ONE Pylontech US5000 since two years without anxy problems.
Today morning ,I received six different alarms from battery monitor:
Internal Failure Module 2
High discharge current Module 2 → System was in “Idle” state because SOC was low
High temperture alarm Module 2
Low temperature alarm Module 2 → Battery is located in the cellar
Low voltage alarm Module 2
Low charge temperature alarm Module 2
For my understanding, I only have one Module as only one Pylontech,
The BMS from pylontech did not show any errors.
System was working normal.
I could delete the alarms but they were flagged afterwards again.
I restarted the whole system and now the alarm is gone.
Any idea what could be the reason for that?
Thnaks,
André
HI, I have the same situation here. I tried to delete alarm, but immediatelly appears again. I did not restarted the system. Did you ever hit the issue again ?
Pavol
Hi!
Till now, the issue appeared only once.
