We have system containing two shoto SDC10 5,12kw modules, and multiplus II 5000Va, The system is working perfectly and com between gx device and BMS seems solid. But sometimes the multiplus suddently with no warning or alarm goes to off state. I can then go to multiplus in devices and turn it on again. But I am puzzled. I have noticed in the alarm menu of the BMS I have and alarm on Circuit breaker tripped. I have never seen this before from BYD, Dyness, or Pylontech witch we have build many systems.
Is it possible that BMS is sending some kind of request to shut down the inverter other than sending 0 discharge current?
All components has the newest firmware except the battery
Best wishes
Lasse workshopmanager in Gsol energy
