Every time I had to expand an existing system, measuring the battery voltage with a multimeter was the chosen way.
I did my best to match old/new packs within 0.1-0.2V and all was perfect. Of course, a little current will flow between old/new packs.
Sometimes, old packs were at 100% SOC, in this case, switched off the system, disconnected old one, connected new one, switched on the system and charge it to 100% SOC. After that, switched off the system, set the DIP switches as required (defined the master) and switched ON all packs and the system.
Other times when old pack were not fully charged I opted to discharge it and voltage match with new pack, followed by system shutdown, DIP switch setup and turn ON all.
