Hi Community. I have the system described above. Unfortunately, the power flow to the grid varies greatly. If I have a larger load of around 1,5kw the power flow goes always up and down from about 2kw to some Watts. Is there no way to set a PID behavior for the Cerbo GX? I’m a bit frustrated.
The system also draws a relatively large amount of energy from the grid with the load
Is there another way to improve the rule properties?
Many thanks for your help
