This is a continuation of original topic from here: https://communityarchive.victronenergy.com/questions/132669/nginx-reverse-proxy.html
You may have various reasons why to put your GX device behind a proxy. For example to shield it from the internet or put it in a DMZ and limit what ports can be accessed and from where.
The original topic contained instructions for Venus OS versions up to 3.33 but started having problems from Venus OS 3.42 and will not work for upcoming version of Venus OS 3.50.
So here I am dropping updated nginx config.
Note: Replace
A.B.C.Dwith the IP of your GX device.
Tip: You can drop the
/websockifypath from the proxy config once you switch to GUI-v2. The/websockifypath is required only for GUI-v1.
Here is the config file that you typically place (on Debian, Ubuntu, Raspberry) somewhere inside /etc/nginx/sites-enabled/ where it is included by default via master /etc/nginx/nginx.conf file.
Note: The config file still uses plain http over port 80. If you enable Venus OS Secure Profile you will have to modify the file accordingly… leaving this as a home work for next time
server {
listen 80;
listen [::]:80;
location / {
proxy_set_header Host $http_host;
proxy_pass http://A.B.C.D:80;
location ~ ^/websockify$ {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_set_header Host $host;
location ~ ^/websocket-mqtt$ {
