Stuck at [1] Connecting. Happens with iPadOS 26.1 also.
Running Venus 3.66 large image on the GX. Was working on 26.0. Works on other browsers on the same devices, so it has to be a Safari issue.
Using http anyone else seeing this issue?
Yes I am having the same issue. I tried clearing all history but no success. It works in Chrome.
Same here, have a Brand new iPhone, expecting everything to be faster then this.
I don’t think it’s a Victron issue since my openWB Wallbox http interface is also affected.
Interesting. Wonder if it will be fixed in the upcoming 26.2 release. If it’s not a Victron issue, it would be nice if they could report and drive the issue to resolution with Apple. I updated my GX today to 3.67, still the same issue.
Still the same in iOS 26.2 Safari.
On Firefox and Chrome it works.
What URL are you using?
If you specifiy IP address this can happen.
Use venus.local instead, it should work.
Thank you for your help.
Venus.local instead of ip-adress works.
Thank’s Nick, I have been using the IP address forever after all, I have a static IP address for Venus thought it would have been the safest bet.
Anyway, as already confirmed venus.local works fine. mdns is fine on the same broadcast domain but those needing to route might run into trouble without helpers. @nickdb Do you know why it’s not working via IP address?
It’s being looked at. Doesn’t affect everyone, could be a bug in one of the open source libraries used. Not sure at this stage. It started with ios/mac os 26 and safari only.
+1
Hangs using IP, but works again on IOS by opening a new tab and using Cerbo GX IP again !
Venus.local works on ipad os
For using IP you have to click on the right circle arrow in safari url line right end
