Hi all, first post so be gentle!
We are fitting a large commercial install at present and reasons beyond our control means we cannot fit an Energy meter to the incoming supply
This is a 3 phase install
We are wondering, is there a way we can buy 3 x 100A CT clamps and install one on each Multiplus and route these to the incoming supply (one each on L1 L2 and L3)?
Thanks
I don’t know the answer to your questions about ct but:
why not use the internal measurement of the inverters ? I you route your energy through the mp2 you can use their internal current sensors. Energy meters (and maybe CTs ?!?!) are only needed in case of using energy between grid and mp2.
Jens
Unfortunately we are only using the AC-In Port and not utilising the AC out so we need some way of metering the current.
Regards
Gavin
Are you using the hybrid generator set up or just supoorting loads between the grid meter and input of the inverters?
I guess that you can’t, for some unknown reason, use a 1-fase MID certified kWh meter on each MultiPlus or a 3-fase kWh meter on the supply line to the MultiPlusses?
I had thought of that but Victron doesn’t state a way to do this. I would certainly imagine there is a way though.
We are doing it in this configuration
I’m much more interested in the AC connection side, since we’re talking AC kWh metering. Correct?
Hi. I actually had the exact same question in my head. Since every multiplus supports CT input for local measurement, that can be used even to zero export on AC-In side - is it possible to use this mechanism with 3 multiplus inverters in 3-phase setup? I mean, there is not even the need to sum the power of all phases, since ESS can be configured to handle zero export for each phase individually. Is such setup supported or do I HAVE to install an smart meter? I know, that despite the fact that recommended meters read via modbus are pretty fast in terms of refresh rate, an analog CT is still the most responsive solution if implemented properly (which I do not doubt since this is Victron)…
