3.60~58 brief setup issue
Love the battery info, but I can’t seem to get the battery to display to show after selecting a temperature. What happened to the brief tank options? I was hoping to finally see all 4 tanks with the battery info in the center, that’s the perfect amount of info for an RV.
EDIT: Playing with it a bit more it appears the selection list is indexed wrong. The list displays the battery when the first temperature is selected. It displays the first battery when the second battery is selected. A workaround is select the second temperature, then select the battery.
I switched back to ~53 to check if the AC Load tile in Overview was also missing the border, and it is. When I reloaded ~58 I saw my RV-C tanks are now back in the Brief view and in the Brief setup. Before this firmware switch battery and temperature was my only Brief options, but the tanks showed up in the Levels view. Now in the Brief setup there are 2 sets of tanks to choose from, Tank totals and Individual tanks. This is on an older Cerbo-S.
Still adding a 4th tanks removes the center battery information, I’m hopeful.
I like the new alert feature. It’s unclear how to acknowledge the alert? It’s showing my aftermarket BMS has lost comm, a leftover from the version reboot, but it’s currently communicating as it should. Neither the inverter or the battery product page indicates an error yet I have a notification.
EDIT: Looks like a refresh of the web view removes the alert notification. Maybe a browser cache issue?
