2xMPPT100/20, Smart Shunt 300A, Pi4 Venus, Bluetooth Connection
iI have 2x MPPT 100/20, 1x Smart Shunt 300A, 24v LIFEO4 2s2p.
Max PV is around 84v.
Max PW is 600W but I only get 350W per MPPT.
Each MPPT can generate up to 2.5KW per day.
Initially, I created a Bluetooth network, MPPT1 Master, MPPT2 Slave. Unfortunately, MPPT Master is limiting the total current at 20A instead of 40A for both MPPTs. Therefore, i want to use pi4 Venus DVCC instead of MPPT network. I am having little problem with USB connections. They disappear after 15 minutes.
Can I connect 2x MPPTs and a Shunt to a PI4 Venus with Bluetooth instead of USB ?
In a perfect world, I wish they all connected with wifis.
If ypu are able to modify programming yes. There arw a few projects available on git and others with members playing with the idea.
Natively no, the venus os is designed mostly for a wired network between critical components.
The real question is why are the pi USBs going to sleep though. I have not had that issue with the one set up i do have a with a pi.
Did you use home made cables or purchased the ve direct to usb cables?
Thank you for your reply.
I can do programming and I will look at that project on git, thank you.
Yes, I used DIY cables. 3 of them. It was pretty simple to make. First I connected red cables as well for power. Same problem but in that case, they were less stable. I disconnected red power cables. They were more stable, but they are disappearing after 15 minutes or so. They are connected to a hub. Hus is not self powered. I will connect them to a self powered hub. I think when the pi4 does not see any power on the red cable, it disconnects them after a while. If I reboot the pi4 from the vrm, they all come back for a while. But I need stable connection to use DVCC and monitoring.
I will post the progress.
I wish they communicated with wifi or rj45 or at least with bluetooth. I don’t like to see too many cables.
Yesh the home made ones are unstable. If you switch to bought ones you will find it quite stable.
Then this. Also had issues when i used hubs. Pi usually barely have a power supply big enough for itself.
I can say thta with bluetooth it is hard on the pi streaming the information. There are other problems you will discover with that method. I see why it is not implemented.
DIY Bluetooth may not be the best option because I need reliable two way communications for DVCC.
Diy anything is not really ideal for something critical. And wifi is also not arls reliable as wired.
The pi will work well with purchased ve direct to usb cables. I have had one in the field for years like that with no issues.
