Guten Morgen,
ich befasse mich gerade noch mal mit den MPPTs. Beim SmartSolar MPPT RS 450|100 ist mir aufgefallen, dass dieser eine Anlaufspannung von 120 V hat. Heißt erst ab dieser Spannung beginnt der Laderegler jeden Tag seine Arbeit aufzunehmen!
Bei den kleineren Smartsolars gilt Batteriespannung plus 5 Volt. Heißt die würde bei 53 V Modulspannung bzw. Stringspannung anfangen die Batterie und den MP2 zu spießen. Das wäre m. E. gerade im Winter ja deutlich vorteilhafter? Sommer wird der Speicher ja eh immer voll werden.
In practice even a bit of ambient light at dawn will have your panels producing close to Vmp. Its current that will increase as light intensity grows.
So in real life it really doesn’t make much of a difference.
I don’t understand what you mean by the inverter or battery overheating. The pv voltage will be bucked down to the scc battery charge voltage you have configured by the scc, regardless of which option you go with.
However what does make a difference ime is the conversion efficiency. Thr rs450 is 96% efficient versus 98-99% for the 250V units. That can make a substantial difference in output.
Personally, having both units, I would recommend the 250/100 as you can basically get two for the price of a single rs450/100 (200A versus 100A). However this can entail more cost on the panel wiring front depending on if you need to go to 3 or 4 parallel strings to achieve your 100A desired charger output (in which case you’ll need a combiner box with breakers, or staubli branch connectors and inline mc4 fuses). A lot of this depends on your panel Voc and record cold temperatures to determine string length.
