2 x multiplus 2 inverters in parallel not discharging at the same rate
Good day
Can anyone help me I have 2 x multiplus 2 5kva
When it discharge from battries the inverters does not pull the same load
Master inverter draws 3500W from battery
Slave inverter draws 245W from battery
Tried to switch master and slave and it stil doesn’t work
All inverters are updated
Hi is every single wire (AC in, out and DC) equal in length and gauge?
Paralleling systems is an advanced install. You really need to be thorough and follow the docs and training. It is not tolerant of errors.
Imbalances only happen due to a incorrectly installed system (unbalanced/incorrect cabling), mismatched inverters (age/usage), popped fuses etc.
Best get the wiring guide out and make sure everything is symmetrical and within installation requirements.
