Need some help with troubleshooting a weird issue. My entire 12V system shut down unexpectedly after running fine for 1.5 years. The Multiplus inverter is on, and I have 120V (US) available, but all 12V is down. I traced the power flow to the Smart BatteryProtect and the Smart BMS CL 12-100.
Power goes into the Smart BatteryProtect, but does not come out. I have a single blue LED on the device. The smart BatteryProtect shows “output disabled by remote” inside the Victron app. Then, power goes into the Smart BMS CL 12-100, but does not go out. No control lights are active at all on the device. The fuse on the Smart BMS CL 12-100 has power on both sides of the fuse.
The batteries are currently at about 70%. All systems in the Victron app seem fine. No red exclamation points. The MPPT controllers (2) show zero incoming watts, but I assume that is due to the BMS not working. I did power off the entire system for 24 hours, hoping it would drain the current from everything (but the batteries), but that did not change anything. There is a large fuse in the lower compartment (see picture), but I have power on both sides of the fuse.
As mentioned, the system ran fine for about 1.5 years and there has been no recent work inside the compartment for several weeks. I am in a bit of a loss why the system shut down. The only thing I am not able to check easily is the inverter due to the way it is installed, but since it is working fine and shows a green light, there is no need to look into the inverter more deeply. I am in contact with the builder of the system as well and I relayed more information to them this morning after checking on the fuse on the BMS. Not shown on the pictures is a Victron Digital Multi Control 200/200A GX. I installed that 12 months ago to be able to control the inverter.
Any thoughts on where to go from here with troubleshooting?
