Multiplus 12/1200, victron smart 100ah, bms v1. When initially connecting the system all works as should. I disconnect the bms from the inverter port to configure inverter, but the inverter shuts down because it lost communication with the BMS. The inverter will not communicate with ve connect, configure or flash. Plug bms back in, all works as expected. I seem to be in a dead lock situation. Can I use an rj45 splitter to program while leaving the bms connected?
Related topics
| Topic | Replies | Views | Activity | |
| Connecting the Multiplus 3000 to a BMS 12/200 via aux 1 and tsense port | 1 | 83 | May 29, 2025 | |
| VE.Bus BMS V2 schaltet meinen MultiPlus Compact 12/2000/80-30 nicht | 5 | 124 | December 4, 2024 | |
| Multiplus an BMS 12/200 Smart | 1 | 56 | September 3, 2025 | |
| Multiplus - BMS Lost, Battery Low | 17 | 267 | March 4, 2026 | |
| Connecting Smart BMS CL 12/100 to the NEW version MultiPlus 2kVA 120V | 0 | 66 | January 12, 2025 |
