Where can I find the manual with description on new feature in EVCS firmware 1.29 ('Allow low excess solar port for auto mode')
Hi, manual will be updated these days. But I can tell you in few words. On previous versions or when disabled, the PV power needs to be at least 1.4kW for 1P or 3x1.4 for 3P. If lower, Auto mode was not starting. With that enabled, it will start at lower power or even 0. It was requested because for off grid, or when the feed-in is not allowed, the PV is throttled when the battery is full.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
54 People are following this question.
