robster avatar image
robster asked
Multiplus II stuck in passthru & won’t discharge.
Hi All,
I have a Multiplus II which is using an Electrodacus SBMS0 as a bms.
When the Electrodacus senses a cell overvoltage it sends a signal to inhibit charging & an ess#3 is displayed on the remote console. My understanding is that charging would be inhibited, but it would be allowed.
Unfortunately the Myltiplus goes into passthru & won’t discharge until the ess#3 condition goes away.
Strangely, although the Color Control screen & equivalent Remote Console show ess#3, the remote dashboard shows ess#4 (discharge inhibited)
Does anyone have any idea what’s going on?
Thanks in advance,
Rob
Multiplus-IIESSCCGX Color Controless discharging
dognose avatar image dognose commented ·
I've got this on my new battery as well. Yes, ESS will not discharge in Overvoltage situations.
I can only assume that this is to protect the inverter, because it's dc input range is exceeded.
You have to wait, until the batteries bms is reporting a voltage within range again. And then, avoid new overvoltage situations.
You can either do this by simply limiting the soc to 95%, or my manually lowering the maximum charge voltage. I did the second and figured out that the battery can reach 98% soc without going overvoltage. anything above will lead to a stuck situation.
It is unfortunately a physical thing, that the batteries voltage will spike, as soon as charging is stopped and it enters a load-free state.
