Is there a possibility to push values to the Cerbo from another source, such as a tank sensor?
I do push power assist settings to the cerbo from my HomeAssistant instance, can i do that also for tanks?
It doesn’t hurt to try and see what’s happening… ![]()
Yes i know, but i dont know where to start.
Slave 100 could be ok. But register? Shall just use a internal tank sensor and try to override it? Or use a blank spot?
I no modbus in that sense, that i can use HomeAssistant to set defined states in cerbo, but thats abiut it…
A place to start is the repository for modbus driver.
In there an Excel file contains all the current modbus registers.
Then, knowing that, you can play with writing to them, the writable ones.
But beware some registers will alter the way the system is working and you can find trouble… ![]()
Also, playing with dbus-spy and see the tank sensors structure inside Venus OS could help.
And if you want, later, you can add those dbus paths to Modbus config file (attributes.csv)
