Wire size and ferrules for Phoenix Inverter 12/1200?
I just bought a 12/1200 Pheonix Inverter and I am trying to hook it up to my battery.
The manual recommends 25mm^2 cable for less than 1.5m.
According to the following source, the smallest AWG with at least that cross section is 3 AWG. Does that sound right?
Am I supposed to just stick the bare wire into the terminal? I know Victron recommends ferrules for a lot of its products, but I cannot find ferrule crimpers for that size of wire. Additionally, I’m not sure what shape ferrule I should be using in this case.
For more information, I was planning on using these cables:
https://www.homedepot.com/p/WindyNation-2-Gauge-5-ft-Black-5-ft-Red-Welding-Cable-Kit-Includes-10-Pieces-of-Cable-Lugs-and-3-ft-Heat-Shrink-Tubing-2G-5B5R-10LG38-HS/319810806
The datasheet also has the AWG number:
grafik
Max is 35mm²/AWG2 so 25mm² or AWG3 should fit good.
PS: The link to the wire isn’t working for me.
Thanks, this is very helpful!
That’s odd about the link. This is the same product on Amazon: Amazon.com: 2 Gauge 2 AWG 5 Feet Black + 5 Feet Red Welding Battery Pure Copper Flexible Cable Wire - Car, Inverter, RV, Solar : Tools & Home Improvement
The main sticking point for me now is whether I need to crimp this with a ferrule or not. I can’t find any 2 AWG ferrule crimpers, and I’m unsure what shape to use here. The bottom has a sort of v-channel to it.
I have heard from other people that they just used the bare wire, I’m not sure if this is recommended for this product or not.
No ferrule, bare wire only. The welding wire linked is good fine-strand wire, you’ll be good with that. Don’t forget to fuse as close to the battery as possible!
Thank you!
