Widget not showing Load
I tend not to update unless I see an error. For me, seeing loads is not a big deal as I can still see the values when I open VRM. But in this case, I will upgrade.
I keep automatic updates ON for iOS and ALL Apps. But the Widgets’ load display has not been fixed yet. Where can it be reported to Victron?
Problem is we have many testers on IOS, i also use IOS and this is not something that has been broadly seen.
Can you all detail your app version and IOS version?
Confirm if deleting and reinstalling the app helps. I know its a pain, but gives info to help escalate.
Thanks
I have iOS 18.6.1 and VRM App 3.0.15
I have deleted the APP and re-installed. It still does not show the Load.
FYI: I have the latest iOS V18.6 and VRM app V3.0.15 and don’t have this issue where Load is missing.
Same for iPadOS V18.6 Works just fine. With one note and that is that the Consumption forecast is only available in text form. Not in the graph.
Edit: I’m using a Cerbo GX MKII
Last question. What GX do you have and OS version .
I have reinstalled the app
but same error, see screenshot. VRM app 3.0.15, iPhone SE on iOS 18.6, Cerbo MKI on 3.62.
I have a CERBO GX F/W version 3.64
