Why is my Victron Energy 50 amp dc-dv charger drawing 16.2 volts, no amps, no watts from my starter
Why is my Victron Energy 50 amp dc-dv charger drawing 16.2 volts, no amps, no watts from my starter battery?
It isn’t “drawing” that voltage from the battery, it’s measuring that voltage - and if it’s measuring that voltage at its input terminals then I’d definitely suggest having your experienced systems installer inspect the full system as a 12vNom start battery definitely shouldn’t be sitting at that high of a voltage!
