Why can I add a section?
By clicking on the small “+” sign at the bottom, I’m prompted to add a “new custom section”. What is the idea? Surely I should not be able to add any section? I should be able to only suggest one?
Fideri
That’s to add a section ln to your menu.
It’s actually good to have shortcuts for stuff that I care. Seems to work with sections and tags. You’re supposed to open the content and use its URL when creating a new shortcut.
Hi @Fideri,
As others have already mentioned this allows you to customise the site a bit to how you would like it.
The changes made there only apply to you and your account, everyone else starts off with the same default set.
That’s fine then. I had misunderstood the purpose. I would change “custom” for “personal” just to be clearer.
