As part off the pop up menu that you get when you click on you avatar, please can you add a link to one’s own posts?
This will make it easy to find any response to posts that might otherwise have been overlooked. There is currently a link to replies, notifications and likes amongst others, but not posts…
Try the ‘Activity’ option.
You can also change the notification level globally or per topic, to watching, which will put updates in the list when you click your avatar.
There are limitations to what can be put where, but typically if you replied to (or created) a topic the level is changed to tracking and any reply will appear under the “unread” category which will appear at the top next to “new”.
